upgrade [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx]
upgrade [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> [any|cdp-match|dhcp-option|fqdn|ip|ipv6|lldp-match|mac|model-number| serial-number|vlan]
upgrade [anyap|ap410|ap460|ap505|ap510|ap560|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> any
precedence <1-10000> [cdp-match <LOCATION-SUBSTRING>|dhcp-option <DHCP-OPTION>|fqdn <FQDN>|
ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]|
lldp-match <LLDP-STRING>|mac <START-MAC> {<END-MAC>}|model-number <MODEL-NUMBER>|
serial-number <SERIAL-NUMBER>|vlan <VLAN-ID>]
| upgrade | Adds a device upgrade rule. The rule applies to the device type
                        selected. Specify the device type and assign a precedence to the rule. The different device types are: AP410, AP460, AP505, AP510, AP560, NX5500, NX7500, NX9500, NX9600, VX9000 Note: Use the ‘anyap‘ option to
                           auto provision any AP regardless of its model type.
| precedence <1-10000> | Sets the rule precedence. Rules with lower values get precedence over rules with higher values. |
                         any  |
                     Indicates any device. Any device, of the selected type, is upgraded. |
                         upgrade  |
| cdp-match <LOCATION-SUBSTRING> |
                         Configures the device location to match, based on CDP snoop strings
| dhcp-option <DHCP-OPTION> |
                         Configures the DHCP options to match DHCP options identify the vendor and DHCP client functionalities. This information is used by the client to convey to the DHCP server that the client requires extra information in a DHCP response.
| fqdn <FQDN> | Configures the FQDN to match.  FQDN is a domain name that specifies its exact location in the DNS hierarchy. It specifies all domain levels, including its top-level domain and the root domain.
| ip [<START-IP> <END-IP>|<IP/MASK>] | Upgrades if a device's IPv4 address matches the
                        specified IP address or is within the specified IP address range
| ipv6 [<START-IP> <END-IP>| <IP/MASK>] | Upgrades if a device's IPv6 address matches the
| lldp-match <LLDP-STRING> | Configures the device location to match, based on
                        LLDP snoop strings.  LLDP is a vendor neutral link layer protocol used to advertise a network device‘s identity, capabilities, and neighbors on a local area network.
| mac <START-MAC> {<END-MAC>} | Configures a single or a range of MAC addresses.
                        Devices matching the specified values are upgraded.
| model-number <MODEL-NUMBER> | Configures the device model number
| serial-number <SERIAL-NUMBER> | Configures the device‘s serial number
| vlan <VLAN-ID> | Configures the VLAN ID
nx9500-6C8809(config-auto-provisioning-policy-test1)#upgrade ap8432 precedence 10 any
nx9500-6C8809(config-auto-provisioning-policy-test1)#upgrade ap7522 precedence 11 vlan 1
nx9500-6C8809(config-auto-provisioning-policy-test1)#show context auto-provisioning-policy test default-adoption evaluate-always deny ap8432 precedence 1 mac 74-67-F7-07-02-35 deny ap8432 precedence 2 ip 192.168.13.24 102.168.13.26 adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1 redirect ap81xx precedence 6 controller 192.168.13.10 ip 192.168.13.11 192.168.13.15 redirect ap7532 precedence 7 controller 192.168.13.10 model-number AP-7532-67030-WR upgrade ap8432 precedence 10 any upgrade ap7522 precedence 11 vlan 1 nx9500-6C8809(config-auto-provisioning-policy-test1)#
| no | Removes an upgrade rule from this Auto Provisioning Policy |
